Hi all, my name is Chris and I am the Manager of Swallows Racing.
We have been busy over the last 6 months developing some amazing new products that no only target common failure areas of these cars, but also improve on the factory design utilising on years of racing experience to create some really exciting products. I am working to create new products all the time so if there is something the owners would particularly like to see then please let me know and I would be happy to look into this for you.
The first complete project has been our suspension kit which is reverse engineered from our own XJS race car. This is now manufactured and 30 kits are ready for pre order and as an introductory offer to owners on this group I will have a limited number of kits at a special offer price of 10% discount. This will be open to the first 5 customers on a first come first serve basis.
We have partnered with one of the leading UK suspension manufactures AVO Technics to design and manufacture exclusive, tailor made suspension kits for the Jaguar range.
After extensive hours running chassis dynamics and testing on and off the race track we believe we have the perfect solution to the overly soft and ageing suspension systems of the XJS model, making the car ride as it should have when the cars were new.
Our development of the coilovers has lead us to develop the perfect road car kit which is also a fraction of the cost of the original manufacture replacements. Saving you on maintenance costs but giving you a huge performance benefit.
Ensuring that we cater for all enthusiasts with the ability to run the car at standard ride height or up to 25mm lower, as well as the ability to have very soft bump and rebound similar to standard or stiffer for track days at the simple turn of the adjusters on each coilover body. Damper bodies are hard coat anodised so there is no horrible flaking powder coat and the best bit is that these can be rebuilt by AVO at any time when needed in the future (No throwing away and needing new unlike other brands).
Our SR/AVO coilovers are THE modification to transform your XJS into the car it should have been, bringing the suspension technology up to date for the modern world.
The coilovers uniquely come in 3 different options depending upon the enthusiast, with options for smaller I.D AVO rear springs and slightly stiffer lowering springs at the front, Dampers with brand new standard Jaguar springs all around and finally the ability to purchase to the dampers on there own to fit the standard springs you currently have on the car to them. (The last option would only be recommended if you have recently replaced the springs on your car or would like to choose your own springs).
Options - (First 5 members will receive 10% off this price)
AVO/SR Dampers and Lowering Spring Kit £1046.06+vat
AVO/SR Dampers and Standard Spring Kit £1444.06+vat
AVO/SR Damper only Kit For Your Standard Springs £1498.06+vat
Key Features -
Swallows Racing GTZ kits are designed for fast road use. Each kit features Twin tube front and rear dampers with the following characteristics.
Dramatic suspension drops (25mm -) Improved lower centre of gravity with optional lowering springs
Shorter bodies & piston rods, for maximum travel at lower ride height
Adjustable damping rate for bump and rebound
Adjustable ride height
Uses race spec 2.25″ I/d coil springs other spring options available depending on use (Contact us for recommendations on track and race applications)
Serviceable damper (Saving on future replacement costs)
Kit Includes -
Front dampers
Front springs (Standard or lowering if requested)
Front Poly bush top mounts
Front damper dust covers
Rear Dampers
Front & Rear bump rubbers
Rear damper collars available for standard or lowering springs
Rear springs (Standard or lowering if requested)
If you are looking for a more track/Race focused coilover then please contact us for information on our 2 way adjustable mono tube systems and we can discuss options for your needs and spec a damper accordingly.
*If you would like fitting here on site then please allow a full day for fitting/ Ride height adjustment/ Corner weighting and 4 wheel alignment in order to perfectly set up your car to maximise these dampers. Items will be kept here until fitting if you have booked for us to fit to your car. Please contact us for individual fitting quotes.
*WARRENTY
Avo UK Ltd do our upmost to ensure that the products made are manufactured to the highest stands using the best materials available. We offer a 12-month warranty from date of purchase against manufacturing defects.
If you would like one of these kits please email me on enquiries@swallowsracing.co.uk
Chris Weston
New Product - XJS Swallows Racing/AVO Coilovers
Swallows Racing
Re: New Product - XJS Swallows Racing/AVO Coilovers
Chris,
That looks a great piece of kit! If I hadn't changed a few years ago to Eibach springs and adjustable Gaz, I'd be very interested in those! I'm sure they'll be popular with anyone doing a rebuild or upgrade.
Swallows Racing
Thank you Paul,
I think you will agree that genuinely it is one of the best modifications you can do to the XJS and could have done with being like this from factory to meet the sleek looks of the car.
Keep an eye out as I will posting all of our new products on the forums to the members first.
Chris
Chris
mark.ellington589
Just bought these and fitting the front next week before we drop the rear. Went for the lowered spring on advice from Swallows bring standard height is actually too high compared to 30 year old springs and ride height sag over time. Hopefully all will be well however as they are adjustable we should get it perfect. I will report back once done.
