Out of date Satnav
andrew.graham97934
Out of date Satnav
Postby andrew.graham97934 » Fri Aug 02, 2024 11:44 am
I am not sure where best to post this question.
I am sure some inventive members of this forum have replaced the obsolete Satnav in their late model X100's with something more useful.
I noticed that my old Samsung Galaxy phone was near enough exactly the right size for the aperture.
Ideally I would like to have something that can act as a satnav plus have Apple Carplay and DAB+ radio.
Does anyone have any ideas how best to achieve that? Ideally I want to keep the original radio head unit set up and make these changes via the Satnav unit.
Thanks for reading!
JimMann
Re: Out of date Satnav
Postby JimMann » Thu Aug 22, 2024 5:51 pm
Hi Andrew, the update for the Satnav in the X-100 model was the subject of an in-depth feature in the September 2020 JE magazine as part of the Modern XK Section. It requires a suitable Garmin system and if you select the correct version, it is fully updateable via WIFI, and it can also have additional features such as reversing camera, etc.
The back issues of the magazine can be found here on the website, but if you have issues, then send me a PM for your email address and I can forward you a set of instructions by email.
Jim Mann
Jim Mann
Banchory
Postby ptjs1 » Fri Aug 23, 2024 12:14 am
andrew.graham97934,
There's lots of ways that you can install a typical Android-based unit giving you Audio, Satnav, Apple Carplay, Android Auto etc. These range from (relatively) very cheap Chinese units up to some of the premier audio units from the likes of Pioneer etc. I recently fitted a cheap £75 unit in a friend's VW Golf and it worked fine. See here for a typical installation in an X100 from an aftermarket installer:
https://www.youtube.com/watch?v=3wfZhd1vqMU
MarkX
Postby MarkX » Mon Aug 26, 2024 5:00 pm
Great find Andrew
