Good Morning,
Apologies if this is of no/limited interest: I needed to fix my offside rear window finisher as most of the clips securing it had failed and there was an unsightly 3mm gap where the trim should be flush with the door frame.
I captured the experience on video. The Jaguar Workshop manual (at least the 2002.5 version) just says to release the 9mm bolt and then remove the trim and that refit is the reversal of the removal process. It is a bit more involving than that! Some say 20 mins and moderate difficulty. Try two hours! Although I did repaint the rubber rear quarter glass trim as it was apart.
https://youtu.be/tXSeDVSGr7o
Hope this might help someone facing the same or similar challenge.
Rich.
Window trim finisher removal and refit
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
