Throttle Position Sensor fix
ISPIZUASTYPE
Postby ISPIZUASTYPE » Thu Feb 15, 2024 7:41 pm
please,
I need to know how to fix a new TPS, 4 contacts for a 4.2 V8 S-Type. I refer to the values of volts at every of four contacts.
Best regards!
(I am very sorry for my so bad english)
Andy P
Re: Throttle Position Sensor fix
Postby Andy P » Fri Feb 16, 2024 6:45 pm
Hi ISPIZUASTYPE,
If you do a search on the forum below for TPS Sensor:
https://www.jaguarforums.com/forum/s-ty ... 8-x200-15/
You get quite a lot of threads regarding that subject.
This is the first one:
https://www.jaguarforums.com/forum/s-ty ... faq-50741/
Hope that helps a bit.
Good luck.
Andy :D
ISPIZUASTYPE
Postby ISPIZUASTYPE » Fri Feb 23, 2024 8:45 pm
Hi Andy
thanks a million!
now the TPS sensor is working well
regards
Augusto
from Spain
