engine motor cover
ISPIZUASTYPE
engine motor cover
Postby ISPIZUASTYPE » Mon Feb 05, 2024 1:07 pm
I have removed part number 2R836A949BF, the engine motor cover, from my S Type 4.2, model year 2003. This engine accumulates a lot of heat in the summer (Spain!), and I am considering the possibility of leaving this cover unmounted. Is there any technical impediment? Is it advisable?
regards
andypryce
Re: engine motor cover
Postby andypryce » Mon Feb 05, 2024 3:37 pm
Hi, I assume you meant the plastic cover put there to make it look prettier? No harm in removing it, though unless the engine is overheating I would not bother, it is not going to make much difference. if the engine is overheating then it needs investigating further.
XF Sportbrake 2020 / XK8 1998
JimMann
Postby JimMann » Mon Feb 05, 2024 4:58 pm
Hi, strangely the SVR models of the latest F-type are supplied without the plastic engine cover fitted as standard, apparently a multi pound cost extra! I don't believe therefore that leaving it off in the hotter climate will make much difference.
Jim M
Jim Mann
Banchory
ISPIZUASTYPE
Postby ISPIZUASTYPE » Tue Feb 06, 2024 10:19 am
thank you
I Will get it in the place where Jaguar did put it.
regards!
