‘Adaptive Dynamic Fault’
Has suddenly appeared and won’t clear on an ‘OK’ reset, the amber warning light stays on and the ‘’mode set buttons on the centre consol are disabled, when they’re used the display says the function is not available and it sets itself back to ‘standard’.
I’ve fully recharged the battery which was new in July 2022.
Has anyone got any knowledge or ideas please?
Thanks, Mac.
Moderator:JohninBham
Mac Booker
Re: ‘Adaptive Dynamic Fault’
It sounds like the quickest route to a solution is via a diagnostics session. That should point you in the right direction, otherwise you could spend time and money checking and renewing expensive components one by one until you've eliminated all the potential suspects. Mike.
Update.
As usual Mike, your advice was spot-on.
A trip to The Jag Doctor where he plugged it in to his diagnostics showed it to be a faulty height sensor on one of the rear shocks. This was replaced and now all's fine once again.
The 'turbo nutter' settings that turn it into a racing car all function properly now.
Mac Booker
Thanks for the update. Glad it worked out OK and hope it wasn't too costly to solve. Mike.
