2007 Jaguar xk Heated seats not working
leelane588
Postby leelane588 » Tue Jan 23, 2024 12:02 pm
Both my Driver and Passenger heated seats have stopped working , Display still shows they are on but no heat comes through
Any ideas on what to check for issue
Thanks in advance
Re: 2007 Jaguar xk Heated seats not working
Postby mike020150 » Tue Jan 23, 2024 6:39 pm
Have you lost any other seat functions? Have you checked the fuses? The seat functions are generally powered through the fuse box located in the passenger footwell, so I'd suggest starting there. Mike.
leelane588
Postby leelane588 » Wed Jan 24, 2024 2:15 am
Hi Mike
Thanks for response, no all seat functions work as should, it is only the heat function that has stopped in both
andypryce
Postby andypryce » Wed Jan 24, 2024 6:21 pm
Hi, check the connector beneath the seat as they can come loose, happened on my XF. Bit odd if both have though..
Also, they will automatically shut off if the in car temp is high, though unlikely at this time of year. Lastly, I wonder if there is a separate fuse just for the heating element, but you would need to check handbook to see if that is the case.
XF Sportbrake 2020 / XK8 1998
leelane588
Postby leelane588 » Wed Jan 24, 2024 11:15 pm
Thank you
Will have a look over weekend
Appreciate the response
