c2c36038 is the OE number for gearshift lever stuck in Park
Moderators:Popsjag, J44EAG
ragnarcarstam
Postby ragnarcarstam » Thu Sep 28, 2023 11:54 pm
My needs to be exchanged, after water dripped own to the gear-shifr. After that, <I could not change the gear position from P.
The shop says it has to be exchanged. Has anyone else had same trouble???
Best regards
Ragnar
2004 xjr, 2008 XJR, Deceased XJ6 Series 3, Daimler double six, XJ40 12.
ragnarcarstam
Postby ragnarcarstam » Thu Sep 28, 2023 11:55 pm
Or rather C2C36038!!!!!
Postby ptjs1 » Fri Sep 29, 2023 11:14 am
Ragnar,
I've amended your post title to get the correct part number.
If you dropped liquid from above (usually coffee!) it can mess up the electrics on the gearshift interlock circuitry. Have you tried manually releasing the interlock solenoid to temporarily get around the problem of getting out of Park? You need to lift the console top to get to this.
I'm posting a link to a thread in another forum which discusses a similar issue. Read through it fully. Also ensure you dealing with a workshop who really understands these cars, and doesn't just tell you that "you need a new part"!
https://www.jaguarforums.com/forum/xj-x ... ark-85682/
