Front Coil Spring S Type R
Hi all, can anyone help me find one of these please? I can't find used and it seems jaguar have stopped making them
Kind regards, Sam.
1989 Daimler Double Six
2002 STR
2002 STR
Re: Front Coil Spring S Type R
Assuming that you wish to retain standard strength original equipment springs, it's likely you will have to resort to buying second hand. Try Autoreserve or Eurojag. Both companies are specialist Jaguar breakers. Be sure to match both front springs. If there is any doubt about the colour coding of the springs from different sources, it is always better and safer to replace both front springs to have a matching pair. Mike.
