Front passenger window not working
bwood727681
Postby bwood727681 » Mon Jul 24, 2023 3:24 pm
My N/S/F window won't go up or down, fortunately at the moment it is in the closed position. When operating the drivers switch I get a click from the passenger switch, that is all. I have tried substituting the passenger switch without success. I did have a couple of incidents when the window would go down on its own and then randomly shut again, I put that down to a faulty alternator which drained the battery [both replaced] but recently nothing. Any ideas or solutions appreciated.
Re: Front passenger window not working
Postby mike020150 » Fri Sep 01, 2023 10:19 am
Since suggestions to solve the problem appear short on the ground, I hope you have managed to sort matters. If not, I suggest that, after checking all the wiring for continuity, swapping the door modules over would allow you to test if the passenger module is faulty. Mike.
