Triple or Twin Carbs
Moderator:jBlackwell
eastendjohn
Postby eastendjohn » Mon Jul 10, 2023 5:08 pm
I have recently received back my XK120 Replica Aristocat from mechanics. While I am please overall, there is still a problem with even modest acceleration being sluggish it's still troubled by a backfire! The car has triple 2" HD 8 carbs with the fabled AED choke. While the car was away I purchased a set of 2" HS 8 carbs complete with inlet manifold and a manual choke adaptation. I am not a mechanic but the swap is pretty basic I think. So do I take the plunge and go for fewer (twin) carbs option, ditching the auto choke to give me a smoother ride? I am a sedate and not a power driver so for me three carbs is an ego trip only.
3.8etypephil
Re: Triple or Twin Carbs
Postby 3.8etypephil » Tue Jul 11, 2023 2:44 pm
The valve timing, clearances, ignition timing, mixtures, or a combination thereof must be incorrect if the acceleration is sluggish and accompanied by backfiring.
Look for air leaks / vacuum pipes disconnected to start with; the cheapest and easiest thing to fix.
Phil
2013 XFR
2008 XJR
PaulGover
Postby PaulGover » Thu Jul 13, 2023 11:01 am
I have recently received back my XK120 Replica Aristocat from mechanics. While I am please overall, there is still a problem with even modest acceleration being sluggish it's still troubled by a backfire!...
Probably far too late to be useful, but have you checked the damper/dashpots on top of the carbs are full of oil? I think you're supposed to use SAE 30 or some such monograde oil, but I always used engine oil as it was handy. Without it, the mixture weakens under hard acceleration, and AFAIK that causes backfires.
eastendjohn
Postby eastendjohn » Thu Oct 26, 2023 12:53 pm
Never too late Paul. Many thanks
eastendjohn
Postby eastendjohn » Thu Oct 26, 2023 12:57 pm
Very welcome input I went through each of these and paid particular attention to the timing and distributor setting. She is purring again thank you
