CONVERTIBLE TOP
lovejags
CONVERTIBLE TOP
Postby lovejags » Mon May 22, 2023 6:43 pm
Hi my 2007 Xkr which has been laid up for 18 months the top was working fine, now it won’t come down when I try Luggage Cover out of position comes up but it isn’t I’ve had the diagnostic machine on and it says B107A hood down switch. Any ideas?
andypryce
Re: CONVERTIBLE TOP
Postby andypryce » Mon May 22, 2023 11:01 pm
I believe there is a microswitch which detects when the hood is down, sounds like it may be stuck. Not too sure about the X150 though. Can you manually lower it using the override as described in the handbook? That may reset it.
XF Sportbrake 2020 / XK8 1998
