Carb assembly
peterheywood52573
Carb assembly
Postby peterheywood52573 » Sun May 07, 2023 5:00 pm
Can anyone explain where the bracket goes.
I am refitting stuff I removed in Jan 22!
Peter
piman
Re: Carb assembly
Postby piman » Mon May 08, 2023 8:38 am
Peter,
while I don't remember whether it is the front or the rear carburettor, it mounts on the bottom studs studs of a carburettor with the short leg pointing to the inner wing, a bit of trial and error should not be too onerous?. There should be a long spring that then goes to the throttle linkage.
I just checked Martin Robey's site here:-https://www.martinrobey.com/jaguar/clas ... r-fittings
The illustration is not quite accurate, as it shows that bracket in front of the carburettor and it seems to suggest that the spring I refered to attaches to bracket 76 which it does not (I'm not sure what that bracket is for, maybe the two drain tubes from the float cahmbers.) The spring attaches to lever 82 and the bracket you show.
