XJS 4 ltr facelift headlights
phillpincott247
Postby phillpincott247 » Fri May 05, 2023 10:59 am
Hi, my full beam switches itself on at random when car is not in use, draining the battery. As soon as you turn lights on the problem seems to vanish, I think its something to do with the dim/dip. checked all relays, they seem to be fine. I'm wondering if its the logic module DAC 6902 but its sealed & an expensive replacement if i'm not sure its the cause. Any ideas guys ?
PaulGover
Re: XJS 4 ltr facelift headlights
Postby PaulGover » Fri May 05, 2023 11:16 am
AFAIR, one version of the XJS suffers from overheating contacts in the fuse box, leading to distortion and potential shorts or (more usually) open circuits. Unlikely to the case, but worth checking the fuse holders associated with the headlights for signs of damage, arcing, burning and so forth.
Postby ptjs1 » Fri May 05, 2023 8:48 pm
Apparently the problem with the logic module is that the solder contacts deteriorate. You could try opening it and examining the state of the solder tracks, which could then be reflowed as necessary.
phillpincott247
Postby phillpincott247 » Fri May 12, 2023 5:20 pm
Thanks, I think I'll take a chance & order a module
Postby davidr » Fri May 12, 2023 5:50 pm
Hi - we did an article on repairing the headlight logic module in the January magazine that may be worth a look
