Hi folks,
So I want to remove and try and repair the A pillar exterior trim, see picture, as it is starting to leak. Is there a particular way to remove this piece, is it just a push fit does anyone know? Thanks.
A pillar trim removal
XF Sportbrake 2020 / XK8 1998
Re: A pillar trim removal
I think you'll find the seal is trapped under the mirror body and so the mirror will have to be removed first to get to the seal itself. Mike.
Hi Andy,
I've got the same problem with my car and found this eBay item which I will buy some time soon, once I've completed a few other jobs.
https://www.ebay.co.uk/itm/175677972535
I thought if you'd not seen it, it may be helpful.
Best wishes,
Simon.
Best wishes,
Simon.
Thanks Simon, ordered similar one for convertible rather than coupe so will give it a try!
