made a start
ARDEN
made a start
Postby ARDEN » Wed Apr 01, 2009 6:51 pm
well i made a start on the jalopy today.
rubbed down and filled a few small rust spots on the front wings.
stripped the rotten headlining out.
stripped the carpets out and found a hole in the drivers foot well.
ripped the front bumper off as well.
http://i5.photobucket.com/albums/y185/M ... uar005.jpg
hole in front quarter.
http://i5.photobucket.com/albums/y185/M ... uar006.jpg
drivers side is ok.
http://i5.photobucket.com/albums/y185/M ... uar007.jpg
general view of the state of the front.
ARDEN
made a start
Postby ARDEN » Thu Apr 02, 2009 7:11 pm
their bodge
http://i5.photobucket.com/albums/y185/M ... e003-3.jpg
the hole gets bigger.
http://i5.photobucket.com/albums/y185/M ... age007.jpg
my bodging begins.
http://i5.photobucket.com/albums/y185/M ... age001.jpg
bit of primer for now.
needs dressing up ready to be stone chipped.
http://i5.photobucket.com/albums/y185/M ... age002.jpg
next job is to repair the front of the crossmember as the spoiler belly pan kept the water in contact with the steel. >:(
ARDEN
made a start
Postby ARDEN » Mon Apr 06, 2009 6:44 pm
well after a full day farting about i have finally repaired both lower rear quarters.
a bit of stone chip and we are done.
http://i5.photobucket.com/albums/y185/M ... e002-1.jpg
http://i5.photobucket.com/albums/y185/M ... e001-2.jpg
http://i5.photobucket.com/albums/y185/M ... e000-3.jpg
ok it's not as good as some of your work, but it will do me. :)
SimonR
made a start
Postby SimonR » Mon Apr 06, 2009 10:44 pm
Good work at the back there - it's looking pretty good.
Keep it going....!
Current cars: [b]1989 XJ-S 3.6 Manual[/b] & [b]2003 XK8 4.2L
[/b]
Previously enjoyed cars: other 3.6 Manual XJ-Ss and Daimler 4.0L XJ40s
ARDEN
made a start
Postby ARDEN » Tue Apr 07, 2009 4:50 pm
http://i5.photobucket.com/albums/y185/M ... e002-2.jpg
http://i5.photobucket.com/albums/y185/M ... e001-3.jpg
phew a mile stone.
the rear end is completed.
next we turn it round and get on with the front. :)
ARDEN
made a start
Postby ARDEN » Mon Apr 13, 2009 9:37 pm
http://i5.photobucket.com/albums/y185/M ... e000-4.jpg
http://i5.photobucket.com/albums/y185/M ... e001-4.jpg
Hmmmmmmmmmmmmmm a few holes in the drivers foor.
Though the inner sill is fine, phew.
The outer sill has gone at the rear as has the radius arm mount.
Passenger side sill and floor is perfect.
All the rot seems to be on the drivers side, must have sat some where bad.
proud owner of
1987 3.6 xjs coupe
1974 5.3 daimler double 6 lwb.
and a nagging misses
ARDEN
made a start
Postby ARDEN » Mon Apr 13, 2009 10:00 pm
to post photo's you need to host them on photobucket or something similar.
then just copy the img code and post them up.
i still have masses to do on the jag, but being semi retired on medicaol grounds does have it's benefits,lots of time. mind yoy the weather has not been good the last week, so i have not got very much done at all.
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Tue Apr 14, 2009 6:44 pm
well i spent the after noon cutting out rust and filling the holes in the drivers foot well.
http://i5.photobucket.com/albums/y185/M ... e000-5.jpg
still got to do the back floor yet. :(
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Wed Apr 15, 2009 6:30 pm
http://i5.photobucket.com/albums/y185/M ... e001-5.jpg
well the drivers floor is done.
http://i5.photobucket.com/albums/y185/M ... e000-6.jpg
look at all the rust that came out
http://i5.photobucket.com/albums/y185/M ... e002-3.jpg
the next job, radius arm mount and rear sill.
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Mon Apr 20, 2009 9:14 pm
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Tue Apr 21, 2009 9:54 pm
well today i cut the front off.
and repaired the front crossmember.
http://i5.photobucket.com/albums/y185/M ... e000-8.jpg
then i had a tence wait for my new project to arive.
http://i5.photobucket.com/albums/y185/M ... e001-7.jpg
1974 daimler double 6.
the misses now hates me.
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Fri May 01, 2009 6:23 pm
http://i5.photobucket.com/albums/y185/M ... e002-7.jpg
http://i5.photobucket.com/albums/y185/M ... e003-5.jpg
front end is finaly done and back together.
i know it needs paint but thats for after it has been mot'd.
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Sat May 02, 2009 8:27 pm
well today i cut out and welded up the rusty rear bumper.
a quick coat of black paint and away we go.
still need to finish bolting them on and wiring up the fog lights.
one more step towards it's mot.
http://i5.photobucket.com/albums/y185/M ... 000-12.jpg
http://i5.photobucket.com/albums/y185/M ... 001-10.jpg
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Sun May 03, 2009 11:57 am
rear bumper is all n and the fog lights are now working.
re fitted the wipers and got them all working as well.
back to the front now.
need to fix the indicators and fit some spots.
then its back to finish off the last of the welding, some new tyres and it's mot time.
bet it fails on something.
proud owner of
1987 3.6 xjs coupe
ARDEN
made a start
Postby ARDEN » Sun May 03, 2009 3:13 pm
front fogs fitted and working.
rear fogs working.
http://i5.photobucket.com/albums/y185/M ... 000-13.jpg
but now the main light switch is playing up. >:( >:( ;D
yet another step back.sheeeesh :D
proud owner of
1987 3.6 xjs coupe
