At Patrick's suggestion I am posting here to see if I strike lucky. I owned this car in the eighties and would love to know her story...
Today I can see on the DVLA vehicle check site that OGX 295E is still registered, though not taxed since 97, and with a badly failed MOT showing in April 2007. I am wondering if she is a whole car still, or just a rusting wreck being broken for spares. If anyone can help with the status of the car, knows the owner or can give the whereabouts of this car I would love to hear from them. Perhaps she may even be for sale?
Date tested
25 April 2007
FAIL
70,242 miles
Test location
View test location
MOT test number
1715 8501 7168
Reason(s) for failure
Nearside Front Direction indicator not working (1.4.A.2c)
Nearside Rear Direction indicator not working (1.4.A.2c)
Offside Front Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
Nearside Front Front suspension has serious deterioration of the bonding between metal and flexible material of an upper support bearing (2.5.B.3a)
Offside Front Front suspension has serious deterioration of the bonding between metal and flexible material of an upper support bearing (2.5.B.3a)
Nearside Front Seat belt locking mechanism does not secure or release (5.2.5a)
Offside Front Seat belt locking mechanism does not secure or release (5.2.5a)
Windscreen washer provides insufficient washer liquid (8.2.3)
Nearside Front brake disc excessively pitted (3.5.1h)
Offside Front brake disc excessively pitted (3.5.1h)
Nearside Rear brake disc excessively pitted (3.5.1h)
Offside Rear brake disc excessively pitted (3.5.1h)
Front Windscreen wiper blade deteriorated (8.2.2)
Power steering pipe(s) or hose(s) leaking (2.3.3b)
Service brake: efficiency below requirements (3.7.B.7)
Parking brake: efficiency below requirements (3.7.B.7)
Advisory notice item(s)
Offside Front Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Nearside Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (
OGX 295E Mark 2 3.4 auto, midnight blue
SimonH450P
1977 XJ6 4.2 Coupe, in need of a lot of love!
Dave Eynon
Re: OGX 295E Mark 2 3.4 auto, midnight blue
Good luck with your search. I don't think that failure sheet is too onerous and I can only think it was undertaken to assess the car prior to returning to the road. It doesn't have any comments for body structural corrosion so OGX may have been in other wise good condition at the time. Hopefully it is being kept somewhere dry. Fingers crossed for a happy outcome.
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
