My car is an original TWR modified 1988 model, and as far as I can tell, with basically standard ignition system and fuel injection. It has a manual gearbox.
The car was off the road for most of last year as I was rebuilding the rear suspension and diff, and now its recommissioned I have a new problem.
It starts first time and runs nicely until properly warmed up, but then 'shunts' or surges badly at low throttle openings - like trying to trickle along at 50 Kph or less in 3d. gear.
This seemed to me like an ignition timing problem, possibly the classic seized distributor centrifugal advance, but the distributor was overhauled a couple of years ago.
So far, I have removed the distributor cap and the rotor arm can be moved easily, and springs back, so it looks like the centrifugal system is OK.
The vacuum capsule holds a vacuum - when I suck and cover the vac tube with my tongue, however, it doesn't move the rotor arm when sucked?
I have carefully synchronised the throttle openings across the banks too, as that can cause low throttle roughness I know.
So, any clues?
Do I need to remove and strip the distributor?
Is there anything else in the vacuum system I should check?
Could it be the throttle potentiometer on the capstan? That was new about 4 years ago too........
All contributions gratefully accepted.
Philip Knowles
Update 09/01/23: Distributor checked out OK, but found vacuum advance connections not holding pressure. So now much better, but think I will go right through the vacuum advance system replacing the hoses and checking each component.
Shunting at light throttle opening when hot V12 HE
pjknowles1968973
