Hi, thinking of fitting external tyre pressure sensors to my 1998 xk8. I check the pressures regularly but feel Bluetooth type sensors would be a good safety feature.
Anyone got experience of fitting them and any recommendations would be good. Thanks Mike
After market tyre pressure sensors
Re: After market tyre pressure sensors
Yes, I have used them previously, worked well, loads on eBay to choose from.
XF Sportbrake 2020 / XK8 1998
Hello Folks
Yes worth all the reassurance they give, Tyre-pal have been reliable for me on both my Jags and Caravan whilst towing. Easy to fit in place of the valve dust covers and set up.
Dave
Dave
Dave Hart
Do the wheels require re-balancing after fitting these sensors in place of valve caps?
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
No, they are very light. Might try these for my XK8
https://www.ebay.co.uk/itm/225168559818 ... media=COPY
If you don't mind buying Chinese.
I might give these a go, from the Chinese county of Yorkshire;
It doesn't take up any windscreen space.
https://www.ebay.co.uk/itm/125279384041 ... BM4pPi8oZh
Finally got round to fitting them, seems to work well.
Thanks Andy , whose did you fit
Like Mike I would be interested to know which ones you went for in the end. It would also be good if you can update us on how get on with them.
2001 XK8 4.0 Coupe in Quartz
https://www.ebay.co.uk/itm/125279384041 ... media=COPY
I put the display unit in right hand side windscreen where it’s fairly unobtrusive. Seems to work ok for £20.
The eBay listing has expired unfortunately. Could you please post the make and model etc? Thanks.
https://www.ebay.co.uk/itm/385619469776 ... media=MORE
There are several on eBay currently as above just type TPMS in search bar. Not sure what make is, suspect they are all the same, Chinese needless to say…
Thank you. I'd be interested to see how they perform.
Will update after few weeks.
Update: still working ok in terms of displaying pressure, couple of issues:
1. Display not bright, in sunlight hard to see
2. The solar panel which is supposed to keep unit charged is pretty rubbish, so either connect it to switched live feed or plug it in once a week to give it a boost.
You get what you pay for…
