Correct part numbers
JeromeNorris
Postby JeromeNorris » Thu May 26, 2022 11:29 am
Does anyone know the correct part number for the rear coil springs on a 1993 4.0 litre Facelift Coupe?
There are a confusing number of part numbers out there.
Re: Correct part numbers
Postby ptjs1 » Thu May 26, 2022 11:33 pm
Jerome,
Assuming you've got a standard 4 litre Coupe which uses the Sportspack configuration, the only difference is whether your car is an early facelift car (up to 188104) or a big-bumper car(post 188105).
The part numbers are: JLM10994 for early facelift & JLM 11311 for big-bumper cars. Just check Jaguar's website here:
https://parts.jaguarlandroverclassic.co ... nd/jaguar/
Be really careful buying anything other than Jaguar or guaranteed OEM springs. There are loads of rubbish pattern springs out there. You'll end up changing them , getting the wrong ride height, changing them again etc. Only buy decent springs and start thinking now about buying adjustable height shocks from Gaz to get the ride height correct.
JeromeNorris
Postby JeromeNorris » Thu May 26, 2022 11:39 pm
Thank you Paul. A Gold Star response.
Mine is big bumper - a million thanks.
