Stop drivers seat moveing back to home position
Hi there, i dont suppose anyone knows how to stop the drivers seat reverting to its home position each time you turn off the ignition?
Re: Stop drivers seat moveing back to home position
From memory, does it not travel backwards when you turn off the ignition, to allow easy access in and out? I think this feature can be turned off from the touchscreen, but I don't remember the exact procedure, apologies.
XF Sportbrake 2020 / XK8 1998
Yes, I found it annoying very early on in my ownership! Assuming you have found the adjustment knob at the side of the steering column for pedal and steering wheel adjustment, the simplest way to prevent this movement is to leave the knob in either the 'steering wheel' or 'pedals' position, rather than the 'Auto' middle position.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
Previous XJs:
