3.5 V8 Oxy Sensors
My 2005 3.5 V8 is showing an engine management light,my local garage says that his reader is showing an oxy sensor problem,just wondering how many there are & their location please guys & does the mention of 'bank 2' indicate where the problem lies.
- 3.8etypephil
- Contact:
Re: 3.5 V8 Oxy Sensors
There are four, a pre cat, and a post cat on each bank. Bank #2 is the left hand bank as viewed from the driving position. The diagnostic code will identify the sensor.
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
Brilliant,thanks for that,am I right in presuming that 'bank' refers to the exhaust?
Thanks,the reason I thought it was the exhaust was that the oxy sensors I have seen in the past have been fitted into the exhaust pipe,being a dinosaur I miss having a Haynes workshop manual to look things up in!
Indeed they are before and after each Catalytic converter on either side. I had same issue on my XJR and turned out to be a leaking exhaust manifold and a failed Cat on one side, eventually sorted after a lot of investigation. Expensive to fix, mainly as new Cat needed. If the car is performing ok may be worth trying to replace each sensor in turn. Having said that I am no expert on these things!
XF Sportbrake 2020 / XK8 1998
And as already mentioned a code reader should say which sensor is at fault
- 3.8etypephil
- Contact:
If you need sensor(s)
https://www.ebay.co.uk/usr/d2pautoparts10
has supplied me for about £20 each, instead of C£4million from the usual sources; they work perfectly.
Should you need new catalytic convertors, likewise aftermarket ones are a lot less expensive, and less power consuming, than those from Jaguar, https://www.ebay.co.uk/usr/turbo_revs supplied me a pair for about £160 a couple of years ago. There was a fair amount of welding involved to make them fit, and attach all the Jag's sensors. They are also a bit more noisy:
https://www.youtube.com/watch?v=-Tmoeit_WyY
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
Thanks for your help guys,much appreciated!
The code showing is 1647,any ideas where that is please guys?
Hi snaefell.being a dinosaur I miss having a Haynes workshop manual to look things up in!
I can't help with the Haynes Manual but I have the X350 Jaguar Workshop Manual you can have,here's the link:
https://drive.google.com/file/d/1s93wwg ... sp=sharing
Over 6000 pages to keep you busy.
Feel free to download and keep.
I use Adobe Acrobat Reader DC which is a free program available for download.
I print the pages relating to the work I'm doing so I have them to hand outside.
The O2 Sensors are mentioned in the Electronic Engine Controls section on page 3345.
Hope this helps.
Take care.
Cheers Andy,thanks for that mate!
- 3.8etypephil
- Contact:
It's the pre-cat sensor, ie; upstream of the catalytic convertor. (A fault in the wiring to the sensor will generate the same code.) They can be entertaining to remove.The code showing is 1647,any ideas where that is please guys?
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
Thanks again,something to keep me amused over Christmas
Take care guys!
Take care guys!
