car colour
nigel8578230
car colour
Postby nigel8578230 » Fri Nov 05, 2021 4:33 pm
Can anyone point me in the right direction in finding a paint colour match. I have a dark blue s type 04 and wish to respray the front bumper
but need the correct shade. Any help welcome
PaulGover
Re: car colour
Postby PaulGover » Fri Nov 05, 2021 6:03 pm
I believe these days the better paint mixing shops have a gizmo they point at your car, and it specifies the mix. With red colours (which fade in sunlight) that can be better than just mixing up the original recipe. Not that I've bought any paint recently.
nigel8578230
Re: car colour
Postby nigel8578230 » Fri Nov 05, 2021 7:45 pm
thanks Paul i will investigate the possibilities down that road.
Re: car colour
Postby ptjs1 » Fri Nov 05, 2021 10:13 pm
Nigel,
Dark blue colours seem better resistant to UV fading. I would just start be ensuring your bumper is clean and the lacquer coat treated with a very mild cutting compound. Then just get an aerosol made up using the proper paint code as detailed on your VIN label.
nigel8578230
Re: car colour
Postby nigel8578230 » Sat Nov 06, 2021 12:39 am
thanks Paul didn't know about the vin code aspect to find colour.
Re: car colour
Postby ptjs1 » Sat Nov 06, 2021 12:53 pm
Nigel,
I think the VIN label on an S-type is on the A-Post visible when the door is opened?
The paint code is a 3-character code, detailed at the bottom of the label.
nigel8578230
Re: car colour
Postby nigel8578230 » Sat Nov 06, 2021 1:20 pm
Thanks Paul when its back from having new coil springs fitted i will check it out .
