E10 and engine converted to run unleadedunleaded
Moderators:iRS, Art1012
bryanplo
Postby bryanplo » Thu Sep 02, 2021 12:02 pm
Help appreciated - in 2017 I had my 4.2 Series 2 E Type converted to run on unleaded. Will it be ok to use the new E10 fuel? I only do a few hundred miles each year.
JimMann
Re: E10 and engine converted to run unleadedunleaded
Postby JimMann » Thu Sep 02, 2021 1:18 pm
Hi, the likely answer is yes to the E10 compatibility (as far as the engine is concerned), but if you want to be safe / certain, go for the slightly more expensive Super grade petrol at the fuel station, it remains at E5 for the time being.
Jim
Jim Mann
Banchory
piman
Postby piman » Fri Sep 03, 2021 12:45 pm
Hello Bryan,
as the ethanol attacks the rubber hoses and anything copper or copper alloys then it is possible you will suffer damage evntually.
Personally I will be avoiding E10 for as long as I can and then adapt or replace all suspect meterials.
andypryce
Postby andypryce » Sat Sep 04, 2021 4:38 pm
Agree with both, I always go for super unleaded, not sure how long that's going to stay as E5 though?
XF Sportbrake 2020 / XK8 1998
