Windscreen washers
robertwilsher67886
Windscreen washers
Postby robertwilsher67886 » Mon Jun 07, 2021 3:22 pm
I’m trying to find the source of a water leak in the windscreen washer system…. I’m trying to remove the washer reservoir to check the connections but having difficulty removing it.
I’ve removed the offside wing liner and found 2 bolts which I’ve removed but the reservoir won’t budge..
I guess there must be another bolt I’ve missed..
Do I need to remove the “under front valance” plastic shield aswell?
Cheers!
jeff1954
Re: Windscreen washers
Postby jeff1954 » Mon Jun 07, 2021 6:33 pm
I think you might have to undo it partially to gain better assess. Iv'e read that you can change the pumps this way. Check through the forum or have a look at other Jag forums.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
