Knock Sensor error resolved
Moderators:Popsjag, J44EAG
Thixendale
Postby Thixendale » Fri May 28, 2021 2:22 pm
I apologize if this is in the wrong place but I wasn't sure where to put it.
I have had a knock sensor error on an infrequent basis but usually thrown up when under load such as hard acceleration. The engine ran well regardless.
I decided to get the cable changed and when it was removed the issue became evident.
Mice had chewed completely through one leg of the cable.
Replacing the cable seems to have solved the issue.
Tony
