After 18 months off the road due to covid I replaced the petrol, cleaned the brakes and greased all round and all ready for MOT, the night before and an indicator wouldn't work, fixed that then the screen wash would only give one squirt and heat up the motor! This is the third motor so I bought two new double headed sprayers a Brass tee piece and some 4mm bore pipe.
I disconnected the Battery for safety.
To get at the sprayers the whole dash needs to come out, the thin bit of wood below the bit tray below the centre dash is only held on with two small captive bolts and nuts, the side veneered dash parts are held on with two nuts on captive bolts up the back of panel near the doors and two screws accessed with the centre panel hinged down (easy to write, hand aching to get at).
The drivers side panel will need the steering column pulled out to its full extent and the column lowered a bit (also best to take the covers off the indicator housing). I also disconnected the speedo drive at the gearbox to allow it to be pulled into the car a little as the dash panel is pulled out and the speedo cable is easily disconnected then.
Both dash panels will need supporting so that no electrical connections need disconnecting, the pipes and sprayers can be easily accessed now.
As you can see this is a job NOT to be done lightly and it took me 3 days to strip and refit, so for those in the midst of a restoration it would be worth giving this some attention first. My sprayers and pipes were the original, very small bores and easily clogged and have given trouble for years.
The water through put is massive now and the double spray heads probably unnecessary and not original.
PS Being older and more tired I only refitted the lower nut on the captive bolts as the top one is hard work to get at! (7/16"UNF).
Best of luck
Getting at the windscreen washers!!?
Re: Getting at the windscreen washers!!?
One of my washer spray heads is loose and I have been unable to get to it! Now I know why and how!
