Automatic Change-up Speed
PeterDavisX300
Postby PeterDavisX300 » Sat May 08, 2021 3:27 pm
Just a very quick question. My 3.2 X300 with 121k on the clock, has recently started revving to 6000rpm before changing up the autobox. Now previously I'm almost sure when I had my foot flat on the floor in kickdown, it changed up about 5700rpm, just in the red-line, but I'm sure it wasn't as high as 6000rpm. It doesn't hit any sort of limited or miss-fire. I suppose some might say I shouldn't rev it that hard anyway, but the car runs well, and the engine is strong. Anyway, I just wondered if anyone knew if there was a fault, or a reason for it seemingly to start revving higher.
Thanks, Peter
1984 Mercedes 450SL Rag-Top
naki
Re: Automatic Change-up Speed
Postby naki » Sat Aug 21, 2021 1:03 am
I think the shift point can be adjusted essentially by adjusting the shift cable, on the 4HP22 box (fitted to all 3.2 AJ16.
Be careful though. Mark the original point.
I would also check the condition of the trans fluid. It should be bright pink. Any other colour than that, and it needs flushing through.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
