Boot opens every time I unlock the car.
Hello again, so ever since we had a super hard frost every time I open the door and release the central locking the boot pops, same when u open the car via the fob. My local shop keeper finds it highly amusing each time I pull up for a bit of milk or something and I get out only for the boot to open
Any thoughts anyone please?
Kind regards, Sam.
1989 Daimler Double Six
2002 STR
2002 STR
Re: Boot opens every time I unlock the car.
Can anyone help please?
Kind regards, Sam.
2002 STR
2002 STR
Sam have you got a second fob that you can try. If it's still the same with that try a battery disconnect for 15 mins. Make sure you have your radio code before doing the latter.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Hi Jeff, I tried disconnecting the battery with no luck and haven't tried the other key fob yet. The boot will open as I open the door from inside after moving the car and it locks itself.
Kind regards, Sam.
2002 STR
2002 STR
Hi Sam,
Have found this thread on Jaguarforums which might have a solution for you:
https://www.jaguarforums.com/forum/s-ty ... red-31074/
Post No 7 seems to have an answer but read the whole thread as it gives another possible cause.
Hope you get it sorted,must be so frustrating for you.
Good luck.
Good luck.
