Rear Parcel Shelf
Tr55vor
Rear Parcel Shelf
Postby Tr55vor » Mon Mar 08, 2021 5:25 pm
I’ve recently changed the headlining in my 1997 XK8 and the company that supplied the new headlining sent enough matching material to cover both the A pillars and the rear parcel shelf and I’d like to have a go at refurbishment of these. However, there were no instructions supplied and I can’t find any on youTube etc. Can anyone on here tell me how to remove the parcel shelf so that I can recover it properly. The A posts are quite easy to remove.
Trevor
Astromorg
Re: Rear Parcel Shelf
Postby Astromorg » Mon Mar 08, 2021 6:48 pm
The shelf itself is held by only two screws in its leading edge. The trouble is you have to remove the seat squab and backrest to get access to them and then also remove the quarter trim panels on each side to allow the shelf to be withdrawn.
If you need chapter and verse on the panel removal procedure, pm me your email address and I'll forward you the workshop manual that you'll find useful for almost any work you want to undertake on your XK8.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
malcolm.phillips45464
Postby malcolm.phillips45464 » Tue Oct 04, 2022 8:48 pm
Astromorg, would you possibly share that with me too?
Astromorg
Postby Astromorg » Tue Oct 04, 2022 10:38 pm
Yes, I'd be happy to forward the info. If you pm me with your email address and your xk's details - year, engine size, I'll get it off to you soonest
2024 XE 300 Sport
