park brake fault
nigel8578230
park brake fault
Postby nigel8578230 » Fri Feb 19, 2021 4:34 pm
Hi all, i have the dreaded "park brake fault" come up on the dash (04 s type). The brake will not engage, i have replaced the battery as advised,reset after but no joy
any help advise welcome. Car drives fine but with MOT next month i need to get to the bottom of the problem.
DChandler
Re: park brake fault
Postby DChandler » Sat Feb 20, 2021 9:46 am
Hello Nigel,
I had the same problem a while ago when my car hadn’t been used in a while. But was lucky that it was low voltage causing the issue. An optimiser did the trick in my case. As you have changed the battery it can’t be low voltage.
Hopefully this link may be of help?
https://www.jaguarownersclub.com/forums ... ake-fault/
Kindest Regards,
Dominic
nigel8578230
Postby nigel8578230 » Sat Feb 20, 2021 4:02 pm
thanks for the link ,will give it a look.
nigel
