Oil pressure warning light
Moderators:Popsjag, J44EAG
timhenson
Postby timhenson » Fri Jan 29, 2021 10:19 am
Hope everyone well
I have got my red oil pressure warning light come on (the oil can icon). The oil level is correct. No oil leaks. Car running great. No noises. Stopped the car within a few miles of it coming on. Milage is 109,000. V8 4.2l XJ x350.
I am wondering if its the oil pressure sender unit faulty? (in fact hoping it is!!)
Does anyone have any throught / comments? Alos where is the sender?
Many thanks in advance.
Tim
Tim Henson
Jaguar 1971 series 3 E type V12.
Rolls Royce 1933 20/25.
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
BrianG
Re: Oil pressure warning light
Postby BrianG » Fri Jan 29, 2021 1:01 pm
Hi Tim, I don't know how long you have owned the car but if it's not long the first question: when did the car last have its oil and filter changed? If you do your own servicing then you can answer that question of course, so if it has clean oil and, hopefully a genuine new Jaguar filter, it may be just down to a duff sensor. The workshop manual says it's located at the right front of the sump. It's only a switch and operates at between 2.2 to 6 psi, so does not give much warning of problems.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
timhenson
Postby timhenson » Fri Jan 29, 2021 1:14 pm
Thanks Brian for info very helpfull. I have owned the car for 3 years and while I normally do the work on cars myself with this car I have had a local garage do the oil change when mot done. Last done in November. Oil still looking very clean. So hopefully the switch i's problem. Sounds like if I take under tray off I will find it. I think I will pre buy a switch and swop and hope!
Thanks again.
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
BrianG
Postby BrianG » Fri Jan 29, 2021 2:28 pm
Tim,
Depending on how many miles you have done since November "oil still looking very clean" may be a clue to the problem. Can you see what type of oil filter they have used? It may very well be a cheapo one rather than a proper Jaguar one. This may cause restricted flow and hence low oil pressure.
Previous XJs:
timhenson
Postby timhenson » Sun Jan 31, 2021 5:29 pm
Hi Brian.
I looked to prebuy one but I was unsure which was correct one so decided to find it on car to be sure. Interesting thing is the green plastic part of the sender fell off when I touched it, so it was probably faulty. Now the wire is not connected the light on dash has go off.
Only saw you comment about oem filter after coming in from garage. I will double check.
Kind regards Tim
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
timhenson
Postby timhenson » Sat Feb 06, 2021 2:05 pm
Just to complerte the knowledge base. With the new sender the light is off so good news.
Good info for others, if the oil warning light comes on, its worth swopping the sender before worrying about actual low pressure
Thanks for the help all.
Kind regards
Tim
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
BrianG
Postby BrianG » Sat Feb 06, 2021 2:28 pm
Good news then Tim! Well done.
Previous XJs:
Andy P
Postby Andy P » Sun Feb 07, 2021 12:21 pm
Well done Tim.
Glad you got it sorted.
Here's To You.jpg (3.55KiB)Viewed 3045 times
Take care and stay safe.
Andy :D
Postby J44EAG » Tue Feb 09, 2021 4:07 pm
My best advice here and based on practical and actual experience.
Buy only genuine Jaguar OE spares when it comes down to any sensor, sender or electronic module. Ensure you only fit parts which have EXACTLY the same part number as the component that is fitted to your car.
Also ensure when you order parts that they are applicable to your own vehicle model year and to your vehicle VIN code. This may be found on the V5C ownership document or by viewing the vehicle identifier through the windscreen, lower near side. You only need to note the last six digits of that alpha/numeric sequence when ordering parts. ie SAJC........G13579.
