1999 XKR pressure/speed sensor valve
davefarr49235
Postby davefarr49235 » Thu Nov 19, 2020 6:29 pm
Power steering suddenly stopped operating. Pump is new and tested OK but analysis points to the pressure/speed sensor being at fault. The valve alone is not available - only complete with a new rack which is obviously very expensive. Does anyone know where I can source a new sensor?
I found one online from a breakers but it’s in poor condition so would like to source an alternative.
Astromorg
Re: 1999 XKR pressure/speed sensor valve
Postby Astromorg » Thu Nov 19, 2020 9:36 pm
I've had good service from both of these used parts dealers
https://www.eurojag.com/
https://www.autoreservejaguar.com/
For Eurojag your best bet is to phone them, tell them what you need and they'll usually tell you availability and price straight off. The website is just an indicator of what they might have - or not!
Just a thought; it's not just the fuse blown is it? F12, 20A in the driver's side dash fuse box.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
