timing belt
rsims193141
timing belt
Postby rsims193141 » Sun Nov 01, 2020 2:03 pm
does my 92 4L AJ6 engine,have a timing belt or chain,and will it need replacing,or do they really last forever
Re: timing belt
Postby davidr » Sun Nov 01, 2020 6:15 pm
Hi - your car has a timing chain and not a belt. Changing it is not a routine maintenance job like a belt would be.
Having said that, it is known for the timing chains to stretch and throw the valve timing out and the tensioners can get a bit noisy.
rsims193141
Re: timing belt
Postby rsims193141 » Sun Nov 01, 2020 7:52 pm
brilliant,thanks for the info,
ng4xjs
Re: timing belt
Postby ng4xjs » Sat Nov 14, 2020 1:19 pm
I actually had a chain snap on my 92 AJ6 (not a pleasant sight).
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
PaulGover
Re: timing belt
Postby PaulGover » Sat Nov 14, 2020 1:52 pm
AFAIR on the 4.2 XK engine the guidance was if you ever take the camshaft timing apart, replace the chain as it's so cheap.
