Replace the Jaguar Radio?
Moderators:robv12, DavidEm
DougX
Postby DougX » Wed Oct 14, 2020 5:54 pm
I wanted to replace the Jaguar radio in my 1999 Jaguar X308. I have been told that the CD 6 stack in the boot is an Alpine unit so I wrote to them with the details of what I was looking for. Their reply was:
When you change the Jaguar radio you will not be able to retain your 6-Disc CD changer, even the Alpine aftermarket radio’s will not talk to it ☹
You are correct in that it will have to be Single DIN radio as there is not much room in the factory location unless you were having something custom built.
This in turn would probably rule out a ‘roll out touch screen’ as it would almost certainly foul on the gear shifter.
A good all round unit I would recommend is a CDE-196DAB, single DIN CD player with DAB/FM Bluetooth and USB connectivity.
You will need some form of DAB antenna, take advise from your local Car Audio Installer. External antenna is always better than a compromise for a screen film antenna. The installers will know what works best for their area and your vehicle.
The unit suggested isn't really what I was looking for. I wanted a touch screen unit. I can understand their response regarding that a roll out touch screen would almost certainly foul on the gear shifter, but has anyone else undertaken a similar replacement of perhaps another radio manufacturer unit and if so what unit was used? Also, were you able to use the Jaguars 6 stack CD player? Any advice woudl be gratefully received.
Andy P
Re: Replace the Jaguar Radio?
Postby Andy P » Sat Oct 17, 2020 5:44 pm
Hi Doug,
Have not done any of this on my car but often read what other people have done :D .
Here are a few threads regarding the transition:
https://www.jaguarforums.com/forum/xj-x ... it-165547/
https://www.jaguarforums.com/forum/xj-x ... xj8-51704/
https://www.jaguarforums.com/forum/audi ... nt-155873/
https://www.jaguarforums.com/forum/xj-x ... io-155898/
https://www.jaguarforums.com/forum/xj-x ... eo-154456/
Hope you find them interesting and helpful.
Take care.
Andy :D
DougX
Postby DougX » Sun Oct 18, 2020 7:25 am
Thanks A.J.P. By the sound of things, it sounds like a nightmare to do. Losing the aerial operation, speaker issues and lose of CD boot player isn’t what I want. I will try ‘professional’ installers and see what they can offer.
cafcpete
Postby cafcpete » Sun Oct 18, 2020 11:31 am
Why do you want to change? Is it because it’s broken or you wish extra features?
1996 Jaguar XJR6(auto)
2002 Jaguar X350 4.2(auto)
DougX
Postby DougX » Sun Oct 18, 2020 12:35 pm
Hi cam Pete, radio fine but wanted upgraded features such as sat nav, Bluetooth, Apple CarPlay etc.,
DougX
Postby DougX » Tue Oct 27, 2020 4:59 pm
Have seen this unit on Amazon, which has had many good reviews. Essgoo Car Stereo Bluetooth, 7 Color 4.1 Inch Single Din Car Radio with Backup Camera Support Touchscreen 2 USB/TF/AUX/AM/FM/RDS, Steering Wheel Control Remote Control £56.99. Anyone tried this unit?
DougX
Postby DougX » Wed Oct 28, 2020 10:17 am
Looking further on the internet, I found a company that is selling the radio surround for the XJ8.
The best price available is from a company called Lakpesh: Check out their website at: https://www.lakpeshop.com/ct24jg06-car- ... 331219.htm
Has anyone else used this product or something similar and if so, was it easy to install? My next venture is to find the appropriate leads that will go with the radio. Surfing the internet again and I find various leads at a variety of prices. Again, can anyone advise me on this?
cafcpete
Postby cafcpete » Wed Oct 28, 2020 6:10 pm
I highly recommend https://incartec.co.uk/Jaguar/XJ-1994-2004 for parts, if you want to go the way of a replacement unit.
Or https://www.discountcarstereo.com/a2diy-jag98.html if you want to add Bluetooth functions to your OEM radio.
DougX
Postby DougX » Sun Nov 01, 2020 10:01 am
Hi All, Just seen this American Radio workshop (https://factoryradioservices.com/) who are able to add a jack plug for my iPad and bluetooth into the existing radio. Obviously, I could send my unit to America to get updated, but does anyone know whether any company in the UK does this. It will save me a lot of bother swapping my existing unit?
Astromorg
Postby Astromorg » Tue Nov 10, 2020 6:19 pm
Depending on how handy you are you might try fitting your own Aux In socket and or Bluetooth receiver. The photos show where to solder in the wiring for a jack socket using the cassette player circuit board and the socket itself can be anywhere you choose throughout the car. A Bluetooth receiver can be added externally or out of sight You need to run an empty (tape removed) cassette to enable it but once inserted, forget it and when the read-out says Side 1 or 2, the Aux In is active. The sound quality is excellent.
I've fitted this to my XK8 and have more detail and photos if that would help.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
DougX
Postby DougX » Tue Nov 10, 2020 7:28 pm
Yes please, if you can send me a ‘private message’ I would be grateful. Many thanks.
JimMann
Postby JimMann » Thu Jan 07, 2021 7:02 pm
A non-member, who obviously cannot post on the Forum has a radio from an XJ8 x308 2002 Executive which is set to the Japanese FM range so goes from 74-ish to 89-ish which he is happy to give away for the cost of postage (£5-£6). It will obviously need a range-adjuster unless someone is really clever with radios and knows how to change it. Non-member found a UK replacement so took the easy option but this may be of use to someone who is a bit stuck.
If you want to PM me, I can put you in touch with the chap. Alternatively, you will find my email on the Modern XK Forum column in the magazine.
Jim
Jim Mann
Banchory
700SN
Postby 700SN » Mon Feb 01, 2021 10:57 pm
Hi there, did anyone find out if there’s a company who can add a USB connector into the existing radio in order to connect a MP3 player or iPhone?
Not sure if it’s easy getting the radio out..?
Stu
Jaguar XJR 4.0SC 2001
Ford Sierra XR4x4 2.9i 1992
Ford Capri Cosworth 2.9i 1985
