I have an intermittent problem with the lock on my driver side door. Sometimes when closing, the door does not latch fully closed and the alarm draws attention to it. It sounds as if there is something loose when I close the door so I plan to remove the door panel and explore.
Can anyone confirm that there are just two screws under the door pull and with them removed I should be able to unclip the panel.
Thanks Ron.
2006 X150 Drivers side door lock
Re: 2006 X150 Drivers side door lock
You need to release the exterior mirror trim piece (3 clips). Disconnect its electrical connector. Then, remove the two bolts you've spotted plus a third one hidden on the trim's top rear edge behind a small cover. Mike.
ron.thomas
Many thanks for your response I wrongly assumed the panel was made up in two parts and I would be able to remove the leather covered insert. I will rethink what to do.
Regards Ron
Regards Ron
