The tyres on my 2002 XK8 are 9 years old, mileage driven 25 k, all tyres in good condition
Your thoughts please, is it time to change them, and if so, your recommendations on which brand of tyres.
Thanks Eddie
Tyres.
Re: Tyres.
Hi Eddie,
I have moved your post from the Technical Bulletins section to the correct location, i.e. "Tyres".
In my humble opinion, the short answer to your question is that tyres, irrespective of tyre wear, should 'ideally' be changed at 5 - 6 years, especially if the car is not normally garaged. Tyres do degrade in UV light (sunlight) and there can be many hidden defects in tyres of your stated age. Given that the 4 contact pads of the tyres on your vehicle are all that stand between you and a major 'off', then it pays to have good quality rubber all round.
Your Owner's handbook should give information pertaining to the tyres best suited to your vehicle, but the general advice is to buy the best you can afford from the main (prime) brands such as the Dunlop SP Sport MAXX range,
Trust this helps.
Jim Mann
Trust this helps.
Jim Mann
Jim Mann
Banchory
Banchory
Re: Tyres.
Thank you Jim
For your thoughts about my tyers
I will get them changed
Regards Eddie mortlock
Re: Tyres.
Hi Eddie,
I meant to say, if you want to check the widest options for your replacement tyres, it is simple to use the Kwik Fit website App - not saying you should buy your replacement tyres there - just that they have a simple approach to showing you the options.
Pull up the Kwik Fit website then simply insert your registration number in the appropriate box and click search - that will show you the options and highlight the different section front and rear.
You can then use that information to shop around - good luck.
Jim Mann
Jim Mann
Jim Mann
Banchory
Banchory
