Replacing Oil Cooler fixings/mounts
clivesaunders
Postby clivesaunders » Fri May 22, 2020 11:40 am
XKR 2002
Can the mounts/fixings for the Oil Cooler be replaced in-situ ’without’ disconnecting the system ?
As the O-rings KSR609001 seem to be on long back-order
Clive
Re: Replacing Oil Cooler fixings/mounts
Postby mike020150 » Sat May 23, 2020 9:56 am
I can't recall having to renew the mounts when I had my X100s but since the cooler pipes incorporate flexible sections, it seems likely, as you suggest, that it should be possible to change the mounts without disconnecting the pipes. If you decide to proceed on this basis, it would be good to hear the outcome. Mike.
