Hi All, i am currently caring out various jobs on my 1988 V12 XJS, I hope someone can help, having removed the rear lights and taking them apart I have lost the small grommet that holds the cable on top of the spring within the light bayonet.
I don’t know the correct name for this part or is it something I can make from perhaps hard board. Any advice would be greatly appreciated.
Thanks Nigel.
Rear lights
Re: Rear lights
Hi Nigel - I'm not quite sure which part you mean. Could you perhaps post some pictures?
rsprince140
Re: Rear lights
HI.NIGEL.WOULD THINK YOU HAVE THIS LIGHT SORTED BY NOW,BUT IF NOT AND YOU STILL REQ AN INSULATION PIECE AS YOUR PHOTO,I HAVE MORE BACK LIGHTS THAN CARS TO FIT THEM ON.AND I WILL POST THE PART TO YOU [FOC] IF IT HELPS,DO YOU REQ ANY OF THE OTHER BITS.SPRING ECT ,CAN SEND AT SAME TIME,SEND A TEXT TO MY PHONE 07719 561701,IF YOU STILL REQ BITS ,HOPE THIS HELPS,RON.
