XJS Headlight issue
pete.scott875
XJS Headlight issue
Postby pete.scott875 » Thu Jan 09, 2020 12:01 pm
I have a 94 Facelift XJS.
The single lens headlight reflectors are shot, and I'm looking for some advice on whether to look to replace them with like or go for a 4 reflector retrofit.
Any advice greatly appreciated.
Thank you
Pete
Re: XJS Headlight issue
Postby davidr » Fri Jan 10, 2020 10:39 am
Personally I'm not a fan of the 4 light conversion but it may turn out to be your only practical choice. 2nd hand facelift light units in good condition are as thick on the ground as unicorn droppings and expensive if you do find them.
Jaguar Classic are considering putting them back into production with plastic lenses but I can't see that happening soon as they'll have to produce the tooling.
Good luck - let us know what you decide
greeban
Postby greeban » Fri Jan 10, 2020 2:54 pm
Have you considered using a specialist company that can re-silver the reflector. I am interested as mine are starting to deteriorate but would like to keep the original look.
