Facelift 91 Aerial removal
xjscharlie
Postby xjscharlie » Tue Dec 17, 2019 8:54 pm
Hello Folks,
Need to remove the electric aerial and wondered if anyone could advise on this as i can see no obvious way and dont want to force it. Also wondered if anyone has successfully used an internal aerial? Thanx in anticipation. Rgds.
PaulGover
Re: Facelift 91 Aerial removal
Postby PaulGover » Thu Dec 19, 2019 12:57 pm
You've presumably removed the RH boot cardboard liner, and can see lots of wires and stuff. Take photos. Disconnect the wires and earth strap attached to the aerial, and remove some nuts and washers under the mounting plinth. As far as I recall, fiddly, and it's easy to drop them, so it's worth clearing and cleaning your boot before hand so you can find them again.
If your's is like mine, which is also a Facelift from 91 (the 99th made, according to the VIN), the main retainer left is a chromed nut in the chromed assembly that passes through the wing. AFAIR it's got two small flats for a spanner and is about 1" deep; it can be resistant to turning, and can turn the aerial assemble instead of coming undone. Indeed, you probably should remove it before the nuts under the plinth.
The aerial motor assembly comes apart quite obviously, and will be full of dirt that's washed down the aerial shaft, and possibly water, and old grease, and the aluminium tube that aligned things will have rotted at the base. I found a replacement brass tube at my local model shop (now closed), and had to rebuild the electronic timer using bits from Maplin (now closed), so if mine stopped working again I'd probably have to buy a new car :-)
In the past I've used a replacement short flexible rubber mast from Halfords - they even had a near matching colour. They don't seem to sell them any more. Here's a link to a similar one on Amazon.
Not tried an internal one.
xjscharlie
Postby xjscharlie » Fri Dec 20, 2019 8:39 pm
Hi Paul,
Many thanx for the sound advice. The aerial is original equipment and has never been removed. It will be interesting to strip it and examine. I may go for the rubber one as an interim~thanx for the link.
Mine's an early Facelift with out Cats. I've been told a few times "they all have Cats" but they dont. Some early Facelifts were shipped with the pre-Facelift set up. Rgds. Charlie.
