I have a Daimler double six 6l v12.
This week I could hear a belt squeal noise which went away after revs.
I started her up this morning in the cold and a noise had started when I steer. After 5 seconds a smoke comes out.
Iv looked at the belts and the small thin belt which goes over the fan stops and starts. I don’t know where to start. Could this be a belt problem or is something stopping the belts rotation. The noise is pretty bad from the steering.
Thanks for looking.
Belts
Re: Belts
Your description is of a rotating component which has seized. The cooling fan belt also drives the water pump so it would be best not to drive the car at least until you have a definitive diagnosis. Ruining an engine by overheating it wouldn't be worth avoiding the cost of transporting the car to your repairer. Mike.
