I’m replacing the rear discs which are past their best. Looking at various sites and MTEC they offer a range all roughly at the same cost. My present discs are plain with no drilling, grooves etc. What do other owners find to be the best. Like an opinion before I order.
Rear brake discs
Re: Rear brake discs
Hi Mike,
I use plain vented discs on my X308 with EBC Red Stuff brake pads,mainly to try and keep brake dust down to a minimum.
I'm the first to admit I only waft around though and don't do much spirited driving
The drilled,dimpled or grooved might look good on a sporty car but I'm not sure they make for better braking under normal driving conditions than the OEM set up.
There is a good variety to choose from nowadays depending on what style you want.
Here is a link to a Synopsis of a test of Cross drilled verses Non drilled braking systems:
https://www.tazcobra.com/SAE_2006010691_Synopsis.pdf
Hope that helps a bit and good luck with your braking adventure.
Take care.
Take care.
Some light reading
Some light reading
