Hi guys
Looking for a new set of rear light for family's XJ6 series 2. Tail lights are not a problem, I've found quite a few places where I can buy them but reverse and reflectors are hard to get. Few popped out on Ebay but in quite horrible state. I would need new or used in very good condition. Any ideas where I can find them?
cheers
Looking for set of rear lights for XJ6s2
rybicki.grzegorz586
Re: Looking for set of rear lights for XJ6s2
Good morning,
I'm having the very same issue as your good self.
Although I think I may have a trick up my sleeve, which may take some time but I can keep you posted on my progress - if I actually achieve any that is!
I have found a man that will carry out rechroming to that awful Mazak (aka - Monkey Metal) - he has discovered that he can weld up the pitting and perforation of the castings and then rechrome the casting.
I have also found that I can take the whole assembly apart and then pout it all back together again - its a bit time consuming but it can be done.
I have also found a source for the rubber seals - both for the body and the clear lens.
So I should end up with a brand new looking fitting.
If your interested in my progress I'll keep you updated.
Ian
Ian
1977 Daimler XJC
2019 Hyundai Tucson
2017 Renault Trafic
2000 Aprilia SL1000
2019 Hyundai Tucson
2017 Renault Trafic
2000 Aprilia SL1000
