Xkr 4.0 engine rebuild
skeltz
Postby skeltz » Sat Aug 10, 2019 12:32 pm
Can anyone advise where I can get replacement piston rings for my 98 xkr fitted with a replacement steel lined engine fitted ? I have been supplied with part no jlm20929 but the oil control ring is to wide to fit the piston. I do have from the original nikasil engine a damaged piston that the supplied jlm20929 does fit so my steel lined engine must have a different part no but British parts say they don’t list any others ?
Astromorg
Re: Xkr 4.0 engine rebuild
Postby Astromorg » Sat Aug 10, 2019 1:21 pm
SNG Barratt list two different ones for the 4.0 XKR; The part number you have, (for earlier engines) and this one - (from engine: 0008180854) JLM21635.
Giving them a ring may be your best bet.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
skeltz
Postby skeltz » Sat Aug 10, 2019 6:29 pm
Thank you for advice will check engine number & give them a call
skeltz
Postby skeltz » Tue Oct 01, 2019 7:49 pm
Apparently 3 different types of piston rings used 1 type for nickasil & 2 types for steel lined the ever helpful cfs motors Coventry identified & supplied the correct rings now running beautifully .
