Replacing Steering Wheel Angle sensor
The DSC fault came up on the XKR today, when scanning the fault it shows C1295 Steering wheel angle sensor- internal fault, I assume the sensor needs replacing or the wiring is bad, but I cannot find the location of this sensor on the column, can anyone give me a guide to where I should be looking? Thank you
Deepdown130
Re: Replacing Steering Wheel Angle sensor
I’m hoping that I’ve managed to attach a screenshot of the workshop manual. That should help you locate the steering angle sensor. It’s the component with two arrows pointing to it in step 4.
Hope that helps.
Gavin
Hope that helps.
Gavin
2012 X351 5.0 N/A
2002 XK8 4.2 Coupe (mostly dissolved and now sold)
