My 1988 3.6 turns over but doesn't produce a spark. I have changed the distributor coil, the rotor arm and the distributor cap. It still turns but no ingnition.
Can anyone advise a way to troubleshoot or a common solution to this.
Forgive my ignorance.
James
no spark?
no spark?
probably the engine ECU,its not telling the coil to spark
hope this helps
hope this helps
no spark?
Sounds to me like the crankshaft sensor that tells the engine ECU where the engine is in its rotation. If this has failed then the ECU gets "lost" and won't trigger a spark. It's a fairly common failure.
crockett169
no spark?
Thanks for the help.
It actually turned out to be a loose multi block connector near the distributor - really hard to work out as it was only intrmitantly faulty and needed a second person to press it together whilst I turned it over. Sorted it with a tight snap tie.
James
_____________
1988 3.6 Coupe
James
_____________
1988 3.6 Coupe
