Replacing the horns 2007 XK
Hi, is it possible to replace the horns on a 2007 XK without removing the front bumper. My low tone horn has failed, so I have bought a replacement pair, thinking it would be a quick job, but it looks a bit on the tricky side. Any help would be appreciated. Thank you.
Re: Replacing the horns 2007 XK
Horn replacement on non-supercharged cars can be achieved by removing the fan cowl. Then, release the electrical connector and remove the stud holding the horn assembly in position. Mike.
