Air Suspension Module - replacement - SOLVED
Moderators:Popsjag, J44EAG
bouncer99
Postby bouncer99 » Wed Apr 17, 2019 7:27 pm
I am about to replace the ASM (behind the rear seat apparently).
Reason is to cure a Air Suspension Fault message on the speedo.
Using my iCarSoft 930 I am getting the message B1471 Headlamp - open circuit/short to ground. I suspect that this is being caused by having fitted replacement headlamp units. The original UK units had the self-leveling feature and the replacement Euro units do not. UK car imported to Germany.
If I replace the ASM for a unit from a Euro spec car will I need to, for instance, to re-calibrate the suspension heights?
Are there any other new problems that I might expect?
Hoping to hear some interesting comments.
SwedishViking
Re: Air Suspension Module - replacement
Postby SwedishViking » Tue Apr 30, 2019 8:06 am
A new or 2nd hand unit will need to be (re-)programmed to the car. As the Configuration data is held in the ECU, a replacement unit will only have this data downloaded and will then behave as your existing unit. You need to change the configuration data in the existing unit to remove the error as it is detecting the missing sensors in the auto-leveling lamp units and reporting this as an open circuit fault.
Best regards Robert
Postby ptjs1 » Tue Apr 30, 2019 12:37 pm
Great input Robert!
