engine management light
My garage and myself can not turn off the engine management light. The error said it was the oxygen sensor.So two new ones where fitted. The garages computer says there is no fault on the vehicle now. But can not erase an old fault . please help this is driving me crazy
Re: engine management light
Try a battery disconnect for at least twenty minutes. Sometimes codes can be hard to erase and "hard dumping" is the only way to clear things down. If the code remains, you perhaps then have to look further.
Make sure you know the radio code before disconnection. You will also have to reset the clock.
See how you get on and please let us know the result.
